jsulse
Trying to sort out the best possible way to power up the HT system I'm currently installing. The system consists of a Panny 65S2 plasma, Denon 4310 AVR, Bluray player, Dish network sat box, Wii gaming console, 2 Yamaha P3500S amps and 2 Hsu VFT-15s.
I have a dedicated 20 amp receptacle and a receptacle in a chain of receptacles wired around the room all powered thru a single 15 amp breaker. The subs will be on the 15 amp room receptable loop. Will I need to split the remaining load between these two receptacles? Been reading some interesting threads re: surge suppressors and amount of protection they acutally provide... Considering one of these surge protectors with voltage sensing because it could solve my problem of powering up the Yamaha amps which has no 12v trigger option. Basically, plug the AVR into the master receptacle and when it draws voltage it powers up other receptacles which the amps could be connected. Would the 20 amp breaker be enough for the AVR and amps? Yamaha's website lists the P3500S power draw at 5.8 amps @ 1/8 power which is "typical of program material with occasional clipping" and 12.8 amps @ 1/3 power which "represents program material with extremely heavy clipping". These surge suppressors are rated at 15 amps so concerned if they can handle the current draw. Wondering if I'll ever use all the the 12.8 amps without incurring serious hearing loss. Been looking at the Panamax M10-HT-PRO and M8-AV-PRO. Pricey units. Worth it or waste? Better options? Will affordable computer surge suppressor strips like Smart Strip
http://www.amazon.com/Smart-Strip-LCG5-Auto-Switching-Technology/dp/B000L9635G/ref=sr_1_1?ie=UTF8&s=hi&qid=1297200951&sr=1-1-spell work for my needs? Would like to Keep It Simple and not get too envolved.
