gene said:
288pF/ft? Are you trying to make amps oscillate? Impressive inductance spec, but how bout increasing it a bit and lowering capacitance.
What the heck does an amp have to do with speaker wires...you expect me to actually connect them to something????
Impressive inductance is a misnomer..the geometry simply defines the inductance as L*C=1031 * Dielectric coefficient..I can generate a cable with .24 picohenries per foot, and 17K pf per foot, using a 1 inch inner dia, and 1 mil kapton dielectric..kapton is 6kilovolt per mil withstanding capability.
The person testing my wires has no such amp instability issue. But yes, that capacitance has to be considered, especially for high bandwidth amps.
gene said:
BTW when I finally publish Speaker Cable Face Off II, I will be doing a DIY Speaker Cable Face Off which will include:
1) DIY designs that a forum member submitted me
2) Infamous Cross Coax
3) Dan Banquer Design, 10AWG Zip
4) Perhaps a few of yours as well.
Hmmm..how about a twisted pair of 500mcm..you can pay the shipping charges..Honestly, it would be rather useless to compare my double coaxes using your equipment, I can give you the numbers right from the jump. The only thing you'll be able to measure that I can't define by equation will be the skin effect dropoff at the higher frequencies because I'm using a finite thickness braid..But for the most part, It'd be more useful to give you a ridiculously low inductance cable to help you baseline your meter setup for the nutso level inductances..
Did pick up two spools of #12 from home depot..ul listed, 600 volt, 15 mil insulation (don't know what type). I'm putting a turntable together with a payup reel, to make a 500 foot twisted pair outta that stuff, cause I'm gonna make my auditorium setup a 5.1 system, with the 12 by 5 speaker panel arrays on the back sides, and my feed snake only works with the amp at one location. I'll be putting all the amps in one rack, and this time feeding the speakers via the 12/2 twisted pair..
gene said:
How about registering on our forums Johnny boy? It only takes a few minutes
That's just what they're expecting me to do.....just because I'm paranoid doesn't mean they're not after me...
Cheers, John
