RichB said:
Some 100 watt AVRs are rated using 1Kz tones and have far less power over the full frequency range.
At 30Hz, it and 8 ohms it may produce much less. Many speakers have high phase angles and low impedance at these frequencies.
Sure, receivers may supply less power over a wide bandwidth, but there is no good reason to think it is a real world problem for most people, at typical listening levels. If people want to use worst case scenarios, then fine, don't use an AVR. Get the biggest and baddest power amp you can afford. The chances are that you'll probably suffer from permanent hearing damage before long. I value my hearing, personally.
I've run B&W 802 Diamonds off a Marantz SR-6008 receiver to prove a point to myself. I could drive them full-range at levels higher than I normally listen, listening to Yello, at a 2.5 meter distance and they (and I) survived the onslaught just fine. Beautiful sound, no audible clipping to speak of. I'm sure had I felt the need, I could have raised the volume further before the onset of clipping.
Now most people who buy 802's will probably never consider an AVR - they'll partner the speakers with all manner of high-end, super powerful amplifiers, but the reality is, one does not need high power in order to drive speakers well.
If a peak, drum kick requires 100 watts, such a receiver will not provide that power.
Depends on the receiver. Receivers are tested using pure tones and resistive loads that are many times more stressful than actual musical signals or loudspeakers. In fact, you could say that it's almost a walk in the park compared to the bench testing which is like an amplifiers worst nightmare.
With actual music, receivers have MUCH more headroom than what is indicated on the test bench! On the test bench, resistive loads are used to keep impedance constant which is many times more stressful than a real loudspeaker that has a constantly varying impedance!
Music has a wide crest factor, which is many times less stressful to amplifiers than pure sine wave testing on the bench. When all is said and done, receivers are relived to be off the bench! It is a nightmare scenario for amplifiers. Everything else will seem like a walk in the park by way of comparison!
