Possible blown tweeter
  • Thread starter Thread starter TankTop5
TankTop5
2,293
0
48
49
I think I may have a blown tweeter or it’s going out. I’ve only heard it sound terrible twice. The first time I chalked it up to intentional distortion in the movie but it was only the right speaker. It’s been two weeks and I just heard it again, same as before just out of the right speaker.
Shortly after getting these speakers I accidentally lightly pushed in the soft dome tweeter but a very light suction popped it back out. I doubt that has anything to do with it but thought it was worth a mention.
Soft dome tweeters tend to be so soft that pushing on the dome doesn't cause any damage and the pole piece is directly behind, so it's not possible to push it far. They can, however, chirp at times, generally due to the crossover going too low- what tweeters and speaker system are you using? It could be the program material- can you replicate this?
Dynaudio Special 40’s... I’ll try to find the spot in the movie where they distorted. Honestly it sounded like intentional distortion in the movie but only out of the right speaker.
I guess it could be a bad tweeter, but I haven't seen theirs fail and their tweeters tend to have low Fs, so my comment about that is probably moot. What source were you using?
Xbox 1 X blue ray to Marantz SR5014, my source an amp should be good. It was loud but not absurd.
If only two isolated instances in two weeks I'd tend to suspect the source more than the speaker....
  • Agree
Reactions: ryanosaur
