Thanks Buckeye....I will try flipping the centre speaker...as for your other suggestions, how should I aim the towers? Better yet, how do i aim the rears and sub as well?
Right now my HT is set up like this:
Room is only 10 feet wide and very long, going to the kitchen, like a rectangle. My couch unfortunately is set up against the back wall facing TV, which is now two feet from front front wall as it a CRT tube, so 8 feet from listening position. My towers are about 3 feet away from each the side of the TV facing me, about 8 feet away from couch .. I have toeed them in, but you say that I am on top of them and I totally agree!! Center is of course on top of the TV. Rears are on stands, about 4 feet high, facing directly at me on the sides of the couch, about 4-5 feet from listening position. Sub is between the right speaker and TV, about 6" from the wall, down firing HSU on a special styrofoam sub lift i recently bought....I am limited as there is a door on the left and right of the towers, no corner to put the sub in. Should I be facing the towers somewhere else buckeye? Or maybe turning down the speaker distance on the receiver?
I am also finding setting the crossover at 100 hz helps tame some brightness. In theory is this true?
JC
