Went shopping for some as my wife is tiring of my blasting the new KEF speakers all the time. I had a set of Beyerdynamic headphones I bought in 1989, I think they were DT660 or similar. IIRC, they were not the top of the line then, but the "second one down the list." Apparently my kids ate them, they're gone.
Now looking around I see a spec given that I don't recall seeing back them. Well two really. One relates to the impedance. With loudspeakers you generally see 8Ω, 6Ω and 4Ω ratings. It seems headphones are all over the map. The other thing that confuses me is the connection. Back in the day, everything was a standard 1/4" plug. Now that seems really rare, I see "2.5/3.5" as common. Is this the tiny ones used on mobile phones, I-Pods, etc?
If I buy a set of KEF M500 for 50% off, will I be able to get a plug adapter and connect easily to the 1/4" HP socket on my NAD receiver?
Thanks for your help!
