Welcome to the forum!
Have you checked out the troubleshooting section of your owner's manual (starts on page 92)? It has some things to check if there's no sound. The first thing that came to my mind was to check if the "mute" is on, but I'm not sure if changing the volume setting would automatically override that.
I doubt this will work, but you can put it into standby mode, disconnect the power cable, wait 30 seconds, then plug it back in. That's what the manual recommends for a strong electrical shock, but it's also for when it won't turn on (which yours does).
You could also try resetting the receiver - that's on page 91. If you can't find the manual, you can get it online or just ask and I'll type up the procedure for you.
