Hi,
I am new to the scene and need help choosing some speakers for a Rumpus room. The room is 6m x 8m (20 x 26 feet) and has a raked ceiling.
I am not installing a home theatre but would like to install 2 pairs of speakers at each end of the room connected in stereo plus a powered subwoofer, the room has a Billiard table and will only be used to listen to music.
Currently I have a new Yamaha RX-AS710 receiver which is rated at 60w per channel 8 ohms. I am currently using some old Jamo E470 floor standing speakers that are placed up on some shelves and do sound great. These speakers are to be used in a home theatre in another part of the house.
The room has limitations on where I can place speakers due to the ceiling, windows, and I don't want to get floor standing speakers as they will be in the way of furniture. I have been looking at getting 2 pairs of bookshelf speakers that can be wall mounted.
I have been drawn to the Klipsch brand and have been looking at either the RP-500m or RP-600m and a Klipsch R-100SW subwoofer. These I am sure will sound great but I am not sure how well the speakers will go wall mounted as they are rear ported. I have also discovered the Klipsch RP-500SA which are classed as a surround speaker, they look like they use the same woofer and tweeter as the RP-500M but in a sealed enclosure, they also angle down so will be directed well when mounted. So these may suit flush wall mounting better but I am not sure if they are suitable as a main speaker or if they will have the volume and range required?
I am hoping for some advice if I am on the right track or not?
What would you recommend for a room of this size that can be wall mounted that are not too large but are full range speakers that will match the receiver and have the volume?
Are the Klipsch RP-500SA speakers suitable to use in this environment?
I am in no way an Audiophile, just someone looking for some great sounding speakers, that will be plenty loud enough to fill the room and look great up on the wall at the same time.
Cheers
Nick
