Please help me choose a reciever
petdoctyr
Hi, Im new to the home theatre scene and need to get a new AVR. Ive done some research and think I've narrowed things down a little. Im looking in a price range of about 600-900$ canadian.
I think I've eliminated Denon from the equation as the recievers in this price rance dont seem to do transcoding/up conversion (whatever you want to call it). I am more interested in future proofing and audio quality than any video upscaling stuff, Ive been told in a couple of stores that the upscaling in AVRs isnt great and the TV (panasonic plasma PZ80U) does it anyway.
So these are the ones Im currently considering
Onkyo 706 - $900
Pioneer VSX01TXH - $750
Marantz 5003B - $800
There are two more which are kinda outliers as well
The Yamaha HTR 6190B (which is the same as the RX-V1800) I can pick it up for 1K but I have a feeling I might be able to haggle down to $800... older model being replaced but I think it might be a great steal if I can get it for that price.
The other one is the Onkyo 606 - only about 550$, much less expensive... do the others warrant the price increases? or will I be just as happy paying less and getting the 606?
Any input would be greatly appreciated.
WmAx
WmAx
Onkyo 706 - $900
If you are interested in future upgrading of the audio part of your system, be sure your receiver has pre-outs. The 606 would be out of the running, of course. Also, all pre-outs are not created equal. The Yamaha I believe, has the same pre section as my RX-V2600, which is superb performance in all regards, and has high voltage 4+ volt output with no clipping, allowing it to easily drive any amplifier with ease to full output and low noise.
-Chris
petdoctyr
What are pre-outs for? other than that am I likely to see a difference between the units? what about Audyssey vs YPAO vs MCACC?
Cpt.America
Cpt.America
Pre-outs are there in case you want to run external amplifiers, instead of the ones built into the AVR. Who knows, you might want/need more power later.
Obviously I can't comment on every receiver out there in your price range as I only own one, but I can CERTAINLY recommend it. I have the Pioneed Elite VHX-01, and it is a fantastic receiver. It processes/decodes all the current stuff, has pre-outs with triggers, is VERY easy to setup, sounds fanstastic, has USB inputs, multple HDMI ins, and is just plain gorgeous.
The only thing I feel I am missing with my VHX-01, is that it doesn't have built in networking capabilities. I think you might have to go all the way up to the SC-05 to get that, which is also a stellar AVR.
OTher then that.. I have zero regrets going with my pioneer.
