please help.. Definitive Technology vs .. S.V.S
apl34apl
OK i,m a new home owner with a even new wife.. she has agreded to let me have a new home sub woofer but i can only spend up to 2k on it so 2000.oo tops. i mostly listen to music.. but u want to feel the bass.,, i,m lookin at the definitive tech SuperCube Reference
vs the high end svs sub
but it dosnt have to be ether of them to i just want to best sub for 2k.. can any one help me.. the room size is 12. by 27 ... 12 feet from me to the sub but it is a long room the other 2 ways,. i have a 7.1 onkio system .. i just want to feel like i did in high school in a car with beat.
bandphan
bandphan
Kind of hard to go wrong with this:)
I cant find third party measurments of the SCR, and would not go by published specs from DT.
but if it were me, id get the Seaton SubMersive @2k
W
westcott
If it were my $2000, I would buy either the Epik Conquest or the Klipsch RSW15. The Klipsch comes in a variety of finishes and would look better, if that is a concern. It also has a flatter frequency response over its range than the Epik. Both average approximately 112dB from 25Hz to 62Hz. The advantage of the Epik is that it does produce 10dB more at 20Hz. But, that is usually the trade off for low range output.
Here is a link that should provide some good information for you to compare and shop what fits your budget and fits your overall needs.
Sound and Vision - Nouisane Subwoofer Shoot Out
P.S. The graph above is useless. It does not provide enough resolution to be of any use.
MatthewB.
I have heard many many subs in this hobby and for the price per performance, you just can't beat the SVS PB13 Ultra, that thing has more tight clean power in huge rooms, than you will ever need. Just an awesome great looking sub.
Warpdrv
Warpdrv
You may want to also add a Seaton Submersive subwoofer to your list....
It is an incredible sub with some of the best SQ I have heard...
It is a Dual 15" firing Opposed Sealed sub.... I have heard lots and lots of subs, and this one is truly at the top of the heap and well worth the money.
http://seatonsound.websitetoolbox.com/post?id=1945927
If I hadn't built my own subs I would have bought those for sure...
Dual, custom designed, 15" drivers with 3" diameter voice coils
A sealed enlcosure built from very strong and rigid Baltic Birch Plywood
Drivers on opposing faces for a completely inert, stablized cabinet that won't walk, shake or quiver.
A robust, high efficiency, 1,000W ICEpower based amplifier with SMPS power supply.
Isolated balanced input eliminating common ground loop problems
Cabinet dimensions: 24.25" W x 17.5" D x 25.5" H
Frequency response: +/-3dB 18-200Hz - outdoor ground plane
And, the Epik has 103dB at 12 Hz:D
http://epiksubwoofers.com/C2.pdf
measured by Nousaine:D
Warpdrv
Warpdrv
No offense, but personally I wouldn't be all that concerned with what a sub can do in a area which is inaudible such as below 20hz - upper teens great, but shooting for flat to 10hz is a waste unless you have a tiny room.
It is nice to have something capable of running in the rumble area, but if takes away from the audible arena, it would lessen my want for such a product.
Your room and placement will have more to do with the response and how flat or rippled its response will become for the listener... great measurements are one thing, what your room does to that response in another.
No offense at all. I think the Telarc 1812 has 5Hz in there:D Why not? Earthquakes go down that low;):D And, if it can, just imagine the upper teens:D I like to see the chess pieces slide off the sub:)
W
westcott
I agree with Warp. Not much content recorded that falls below 25Hz so performance below this level becomes rather irrelevant in real world listening.
moreira85
Sub
COME ON GUYS! He said he has a new wife! As a SVS PB12 +2 owner why are we recomending SVS to him. If he gets the PB 13 and his wife is home when they deliver it he will be in big trouble!:eek: And even more trouble once it is hooked up.
Just an FYI I have 24x16 room and my SVS is more than I will ever need.
Until one day when i want another.
Go with the PB13
mike c
mike c
i don't know if i want to go for that 10hz extension myself. the right and cheaper thing to do is multiple sealed mal-x's playing the last octave. but resale value on that is crap.
other options are 8 ultras in sealed mode (with linkwitz transform) or 5 ultras in 15hz mode with no room compensation
W
westcott
Go with the PB13
That is why I recommended the RSW15. It performs like the Conquest, it comes in a nice furniture grade finish, and it is a size your wife can live with.
apl34apl
confused svs subwoofer
ok so should i go with the svs.. i just want to feel the bass.. for under 2k..
so i just want to know the sub woofer that will make me feel the most bass for 2k
Sheep
Sheep
That is why I recommended the RSW15. It performs like the Conquest, it comes in a nice furniture grade finish, it is a size your wife can live with, and I own it and get irritated every time I see something else recommended.
Fixed.
SheepStar
