3db
3db
I played today with REW after getting the UMIK-1 mic. That being said, using JAVA on windows 7, I cannot pick individual channels from the menu so I think I'm getting the response from all 5 channels. I dont how to pick individual channels.
These curves are for the bedroom. The first curve is the response with no smoothing with YPAO set to flat.
The second curve is identical to the above but with 1/6 smoothing applied
The last curve compares YPAO FLAT and Through ( bass management but no room correction) with Through being the green trace
William Lemmerhirt
William Lemmerhirt
Iirc you have to use asio for individual channels. Can’t remember though as I haven’t had access to my rew for a long time now it seems. Laptop down...
One thing to do is change the vertical scale(graph, limits) to show 45-105. A 60db seems to be the standard and will be more apples to apples when others look at them. It will also show more accurately the response. Warts and all lol.
V
VMPS-TIII
With REW for Mac you select the speaker you want to test when setting up the pink noise configuration. I would imagine the PC version is similar?
