So I had another recommendation that it might be the length of the cable. I hooked the projector up with the HDMI Out 1 cable that went to the tv, didn't work either.
I then tried swapping back to the TV, and couldn't get a picture on the tv. tried changing inputs on the tv again, no go. Power cycled everything, nothing came up. Even when I went into the menu settings, when the receiver should have been displaying an image, no go. Also tried different inputs (xbox, cable box, apple tv2) and I can't even tell you what combination it takes to get it to work on the tv its so random.
Is there a certain order I need to power things on? I've tried every combo I could think of.
I can't seem to get anything consistent out of the receiver, I almost wonder if it's not working correctly.
