Pioneer VSX-21txh sometimes won't power on, unless...
Tungsten06GT
I unplug the power cord and plug it back in. Neither the power switch on the unit itself or the remote will turn it on unless I pull the main plug, wait a minute, and plug it back in. Does anyone have any idea what the heck the problem could be?
tom67
Hitting the zone 2 power button perhaps? Drove me crazy with my Yamaha until I realized the remote on button was activating both zones,but only turning one off...
Tungsten06GT
That's an interesting thought because I wouldn't think the unit has anything wrong with it, since pulling the plug is probably putting it back into some sort of default state. I can't pin point any sort of frequency of how often it happens though, but I will definitely look into the manual better for some sort of situation like you mentioned.
Clump
There is a known issue with not powering on randomly from the remote. There's a firmware update to fix it, but you have to take it to a service center to get the update applied.:rolleyes:
Turning Kurolink on will keep it from happening, but then you can't reassign inputs, etc. If you don't need that try with Kuro on and see what happens.
I haven't heard of the power button on the unit not working, so you may have a whole different problem.
I hope this helps.
