A/VUSMCSGT
A/VUSMCSGT
I'm looking at about 4 different receivers for about $500. The Pioneer VSX-1015TX has been the most impressive. Anyone who has it, or knows about it, please give me the pros/cons about it. Thanks.
S.R. Johnson
S.R. Johnson
well my friend I can tell you that i have the 1015 and it is a great bang for your buck receiver. I dont have any issues with the receiver and the remote that it comes with!
Blundaar
I'm also enjoying mine immensely. I love the fact that I can plug an amp on a whim (I may buy a 2-channel amp for non-DD / DTS listening). One of my better purchases.
Zuke
Zuke
I can say ditto..
jaxvon
jaxvon
I have also been enjoying my 1015TX. I can think of one beef off the top of my head:
If you want to use the multi-channel analog input (that is, if you want to listen to a DVD-A or SACD), you need to physically get up and press a button on the front panel to select that input mode. There is NO function on the remote that does this. For those of you with a normal setup, this is probably fine. But for people like me, where my receiver is tucked away and sideways, it stops me from using the multi-channel analog inputs.
Here's a picture of my receiver. You can see why I have a beef:
A/VUSMCSGT
A/VUSMCSGT
Thanks for the input guys. My most important want in a new receiver is good surround sound. The receiver I have now just doesn't have enough. It's a Pioneer VSX-D510, about 4 years old. It was part of a system in a box with center,L/R, and both surround and sub for $400. Even with the volume almost all the way up, you can barely hear the surround sound speakers, even with the fronts turned down and the surround way up. I LOVE loud movies with realistic surround sound. Is this the receiver for me??? I think it is, especially with the THX Select 2. Thanks again guys.
Blundaar
No doubt. It's a better movie receiver than for music (in my opinion). It handles my hogs (NOTE: Full size rear speakers. Overkill for the living room, but I love it!).
Bluesmoke
If you like playing loud and want a 7.1 setup, I think (depending on how power hungry your speakers are) the Elite series is more up your alley. They'll do a better job at driving all the speakers with power than the 1015TX. In stereo mode, the 1015 is strong, but as you add center and rears, the power drops considerably.
A/VUSMCSGT
A/VUSMCSGT
My receiver budget is about $500. I have a $1000 budget from my wife for A/V stuff I need. All I need is a receiver, DVD player/recorder, which I found for $129, and sub/4 surround/center speakers. With the DVD for $129 and the Pioneer for about 500, a have about 350-400 for the speakers. What speakers out of these do you think would be the best?
http://forums.audioholics.com/forums/showthread.php?t=19811
Bluesmoke
If you're going to be running micro speakers, or small bookshelves, the 1015 will do so with power to spare.
A/VUSMCSGT
A/VUSMCSGT
And the surround will be loud and clear??
What speaker package do you think will give me the best performance with the 1015 in a 13.5X19' open living room with cathedral ceilings?
Bluesmoke
Is your heart set on a small surround package? If it's possible, try and get the best Floor standing towers as you can. IMO, those are the most crucial sounding devices for home theater. I loath small speakers for mains. No matter how good they are, big mains just sounds fuller. Get the 1015, 2 front towers and whatever surrounds you want to get.
Or better yet, to aphease your wife, buy things slowly but with quality. 1015 and then 2 towers, a matching center will do you good. When she gets used to listening to your kickass system, it will be HER demanding that you spend the extra $$$ to buy the rest. Then, you can slowly add surrounds and sub.
Worked for me (GF, not wife), my cousin, and my uncle. I think it will work for you. :cool:
A/VUSMCSGT
A/VUSMCSGT
I know what you're saying about buying quality things slowly if I have to. For the front, I have DCM 3-way stacks with 12" subs. I bought those about 3 years ago for $400, and they perform very well. So all I need is the sub, center, and surrounds. I have the money to buy whatever, but even if I buy a little at a time, my wife doesn't want me to spend too much. I could spend mllions if I had it, but my budget is okay I think. I'm not set on small surround set packages, but I know for 350-400 to get sub, center, and four satellites, I almost have to get a package. If I bought them all seperately, I'd probably be spending over 400. Any suggestions as to buying all seperate, or a package out of the ones I'm looking at?
cthomp
Worth a Look
For $350-400 you may want to check out the Hsu Ventriloquist VT-12
www.hsustore.com. They are small speakers with a BIG sound! Read the
reviews at their website. Their VTF-3 sub was reviewed recently by
Audioholics! The only other way, is to buy pieces as you can afford them.
Good Luck! :)
Blundaar
Another DCM user. Cool
Bluesmoke
A/VUSMCSGT
A/VUSMCSGT
Pioneer's website says the Elite does have 2nd zone and a 2 year warranty. Around where I live, all I have is Best Buy and Cicuit City. I know I can order online, but I don't like doing that. I just feel better having an actual store to go to if there's any problems, and if I need to return it for any reason, I can easily with no shipping or problems. Best Buy nor Circuit City doesn't have the Elite, they have the 1015 for $474.99 when you buy speakers from them at the same time, which I might be doing. Without buying the speakers from them, it's a little over $500.
jaxvon
jaxvon
If you can, find a friend or someone you know that works at Best Buy. The employee discount will take the price on the 1015TX down to under $333.
