Hi again, well after working and reading and planning all weekend, the finale came and all I get for output's from my SC-67 pre-outs is FRONT.
Talk about frustrating!!!
Read every page of the online manual and all troubleshooting guide at back, can't get the other preouts to output anything.
Page 75 to 78 says if I select anything but 9.1, then internal amp is locked on. Checked this, I am on 9.1.
Also says if I turn internal amp OFF (default is on) then all speaker terminals are off and supposed to run on preout terminals only.
Did that, several times, and even went back in to ensure it registered and stayed off, it did. Yet still no preouts other than preout FRONT.
Took every set of Cerwin Vegas I had, disconnected them from their respective preout, one set at a time, and plugged that set into the FRONT preout, just to test my amps and speaker sets and wiring. They all work great when plugged into FRONT pre-out. Pre-outs Not working are: Front height, Front wide, surround, surround back, center. The 2 sub outputs are working.
This thing is brand new.
Any ideas, could sure use some help. Thanks
Equip: SC-67, 5 CV 1800's, 12 CV cabinets, 3 CV powered subs.
