The road to audio paradise...
Hi Larry,
Ouf! Talk about some changes and new ideas here. That's perfect, that's how it goes in life.
1. I check that nice AV cabinet TV stand. Looks very nice.
Now, if you go for a receiver like the 876, which run quite hot, you want to make sure that there is at least 4" of free space on top. And a small fan on top will help too, that's very easy to install and it's cheap too ($20).
* OK, let me put it this way: I got a nice home entertainment center that only accomodate a 27" TV, with closing doors for the TV, 2 big drawers, compartment for VHS, components space with two wood doors, compartment for components with two tempered glass doors. It's quite big and made of oak.
Now, I did some modification to it: I removed all the doors, the back panel and I even remove the middle support, so it can accomodate my 55" widescreen TV. I even lift the top to another 3 inches to accomodate my TV.
Radical change, but it seves the purpose perfectly and you cannot tell if it comes brand new like this already (I'm talented with wood working and remodelling things to custom made). My Onkyo 876 sit at the bottom right with 6" of free space on top. I remove the two huge drawers in the middle, plus the pull out shelf for a turntable. Six inches higher of my 876, I put my Rotel CD player. In the middle section, where the drawers used to be, I got my huge center speaker, and below are my Denon Universal DVD player and my Toshiba HD DVD player. On top of my cabinet (53" high), I got a couple Blu-Ray players. I'm all set with everything open on the front and rear, plus my 6" of free space on top of my 876. I could even take out two components, no sweat, no need for all of this. But the way it is now, it looks very sharp and I build some nice acrylic shelf for the two very top components (a pro job you can say).
--> All this to say, that the old days are gone. An audio cabinet should always be open on the rear, period, it is easier to change components, access all your wiring, and let your components breathe at one of the most important spot. Stacking components on top of each other does not looks good and for a receiver in particular, you want always 4" or so of free space on top.
Now my sides are close, so as yours, fine. But now, I decided to even open the front. No glass doors (glass doors sucks for sound quality anyway). And I also remove all the wood doors (4 of them), and I remove 2 big drawers.
Now, in your case you don't have to do that, it's a different AV cabinet with some nice elegance. But you can remove the rear cardboard cover, at least you gain something useful and easy to do. Where your receiver will go (if you decide now to go that way, cause you don't seem to be sure anymore), you can only take the front glass door on that side. Leave some 4" on top of the receiver, and voila. Or leave the glass door on front, and leave the back cardboard cover too, but instal a dual (4" fans) in the top part of the cardboard by cutting just the right opening for your receiver (about 8" by 4").
In the end, if you and your wife like (I do) this AV cabinet TV stand, go for it, it will suit any components that you might decide to acquire, hot (876) or ICE cold (SC-05).
By the way, I believe the SC-07 is more alert than the SC-05.
2. Now, you're talking separates. I'll say, go for it. Couple Emotiva amps with a nice pre/pro, like the Onkyo PR-SC886P for example. More money, but so what, better looks, less heat problem, and better sound. If I'll have a couple thousand extra or so, that's what I'll do for sure at your place.
3. You already know the score about cost and the great value of the components that I already mentioned to you previously, so no need to repeat myself here.
4. Emotiva or Outlaw, the choice is yours, they are both great.
Me, I personally like Emotiva for the better looks, the great value and the performance too. I think that an XPA-2 with an XPA-5 combo is a very nice solution. But this is your choice, not mine.
5. Parasound amps are also excellent. I f you get a good deal on one or two, go for it, they are top notch amps. But you already knew that.
And Audio advisor is a top notch place to shop too.
6. The Mirage OMD-28, ouf!, it is the top of the line Mirage speaker for the 2007-08 year. It retails for $3,750. It's a big speaker with serious heft to it, and two big 8" drivers. I will highly recommend that you give them a listen, if you can. How much better will they sound compared to your OM-9s?
Only you can answer this in your own room with your own equipment.
What, who do you think I am? Jesus walking on water?
7. I check in my mags about reviews of the OMD-28, but nothing.
Just keep looking on the wide web world, and I'll do the same. If I find something, you'll be the first one to know.
8. OK Larry, that's about it for now, according to your instructions.
Till next time, and my bests to you and your wife,
Bob
