Pioneer Elite PRO-1140HD Media Receiver
Razorback_Fan
Who has this panel is using the media receiver? How easy is it to use and how did you set it up to your home network? All info appreciated. I'm about to pull the trigger on the purchase and would like to get as much info as possible
F
flyv65
I'm still getting mine all set up: the ethernet cable is due in sometime this week. I'm looking forward to trying out the WMG software on this panel. BTW, I mounted mine using the Digicom pivoting flat panel mount for about $150...I'd tried to find the Pioneer mount, but it wasn't out there, and the digicom one seems to be working fine (after I calculated the spacers needed and bought long enough bolts).
Bryan...I'm in awe of mine: if you can afford it, pull the trigger...
Razorback_Fan
Cool how do you like the picture...is it everything it's cracked up to be? Also how long did it take you to get it from abe's?
F
flyv65
There are about 5 settings for the picture: pure, standard, dynamic, game, and movie. you can change each of these to suit your tastes EXCEPT dynamic, which, coincidentally, is the worst one, in my opinion. Game, straight out of the box, is abit on the greenish side and noticeably bright, but not bad for Doom3 or Forza Motorsport (or DOA3). I set the color temp to midlow for all settings, bumped the contrast down some on movie, and other than that I haven't diddled with it since. Of course, I still haven't found my copy of DVE yet so I'm hoping to get it dialed in this weekend (if I find it).
From my viewing position (about 11 or 12 feet away), the picture is, well, the only way to describe it is lush: in the beginning of LotR when Frodo is sitting under the trees and hears Gandalf coming, the picture almost seems 3D, with none of the overly crisp edges or supersaturated colors I've come to expect from LCD. The same applies to the Rivendell scenes. The blacks can be stunning in the right environment: I popped in Underworld this past Saturday afternoon to see what impact the western windows had on the picture quality. Suffice it to say, dark movies are best viewed in a low light settings (but you knew that, or you wouldn't have been shopping plasmas). At night, or with the blinds drawn, the 720p image is everything I expected and more-you can just about tell if Kate Beckinsdale is cold in that tight little vampire suit of hers.:D I'm running DishHD to it now for my TV signal, and it does as good a job of scaling Hd and nonHD signals as it does showing the 720p signal from my player-the thing is just a pleasure to watch.
Shipping from Abe's took about a week: I placed the order late Thursday morning, and the following Tuesday the speakers, tablestand, and wall mount showed up here in Denver...the monitor itself was delivered 3 days later, Friday morning between 7 and 9 o'clock, so all in all it took 8 calendar days from ordering to delivery.
Bryan...you're gonna love the bloody thing:) ...
O
Ohmen
I use the media server for my mp3's. It actually works better than my D-link media server for music. I like to view the music by folder than just browse to the artist than cd and play. The only problem I have is with all my music right there at my finger tips. I am constantly flipping from one song to another. :)
F
flyv65
Ohmen:
Have you used the media gallery for anything other than music? Are you running the digital out from the monitor to your receiver for tunes? I thought I'd go home tonight and make sure I had WMG on the tower downstairs already for when I get the ethernet cable in (I'll be running the cable from the monitor down through the crawlspace and over to the office for computer access).
Bryan
O
Ohmen
I have played around with music,pictures and video. My D-link media player displays the photo thumbnails faster so I use it for photos and video. I am using the optical output to a yamaha 2700 receiver. I am using TVersity on my computer rather than wmp. If you are just getting this tv you should check out this thread for a good starting point with the video settings.
http://www.avsforum.com/avs-vb/showthread.php?t=731242
RedlineRonin
RedlineRonin
The media center box is the single best idea that pioneer ever had, don't know why they went away from it, but yeah, i would definitely buy the set.
Warpdrv
Warpdrv
Nice displays guys...
About the media center... If you want the best media center available ever, get a modded Xbox with XBMC. You will never find a better interface to stream media from your networked PC. They are simply amazing with a HD hookup and Optical audio... Streams music, movies, pictures... trailers off the net.. you name it... Cheap, and worth every penny...
Just thought I would add my worthless 2 cents ....
Warp
E
EuroVW
Hey Razorback,
Setting up the Home Media Gallery is pretty straight forward. First you can either set the TV up with a static or DHCP assigned IP address from the setup menu. From there you will need to install Media Connect or just download that latest version of Windows Media Player (Currently 11 which includes Media Connect) from the MS website on your PC. Launch WMP and configure your library for "Media Sharing" (under the library tab). It should see the TV if you hooked it up first. After importing your music into WMP it will be available from the Media Gallery. If you have any issues give a shout.
-Jason
Razorback_Fan
Thanks for the tips....I'm taking delivery of the set today. I will be getting it installed in a few weeks so trying to do my homework beforehand.
G
glamisman
Pioneer Home media Gallery
I am in the process of setting up a networked PC and my Elite PRO-110FD. For a streaming slide slide show it works not as snappy as I though it would be, Pioneer advises me to reduce my image sizes so that they stream faster, makes sense to me. One issue that I am having is the streaming of DVD's that are ripped to the hard drive. Windows Media Player 11 (WMP) does not support some file types and the Pioneer Home Media Gallery (HMG) has limited support also. Trying to find software that will rip the DVD to the harddrive and have the HMG find it an play it is a struggle. I do not know if WMP is required to be used as the streaming source for the HMG or not. Has anyone out there done this before? All of my music CD's ripped fine and I would like my DVD's to be the same...
Z
zeitboy
limited streaming capability
I have the Pioneer Pro150FD plasma and have am not impressed with the Home Media Gallery options or performance versus a stand alone media extender.
- Photos take too long to stream, display, and have limited formatting options
- Music GUI is limited
- Video formats are limited, Windows Media Connect and WMP11 only deal with a few file formats, TVersity is a bit more flexible but again limited chice of file types.
IF you want ther performance and flexibility of a media extender then the Pioneer won't deliver.
G
glamisman
My picture/slideshow images were 3456 X 2304 and took forever to load. Pioneer recommends reducing them to a smaller image, 1920X 1080. They load faster but are not as sharp. I have been trying to figure out what DVD ripper/video converter is best to use with WMP 11 and HMG, so far not much success. Yes, the formats that HMG locates and can play seem to be limited. I am far from being a video techie type and it seems that all video/audio formats are not the same, so if anyone is riping DVD's and streaming them from a HTPC and using the HMG and it looks good/sounds good please, save me/us some time and let me know what software works...
Z
zeitboy
Still unhappy
I'm sure it's easy to reduce the photos to display them on the display, but then I have duplicates of thousands of photos on the server. I don't want to have to reformat my media for each device on the network. Just connect each device to the server, find the relevant media, and play. Imagine if you have to format your photos differently for each size computer display you used...
Home Media Gallery is still a work in progress - very rough edges and slow performance. Clear specs aren't published and it's not clear if/when any software upgrades will be available. Finally, I can't find any advanced user groups or forums, like I can for the other media server products that are PC based, so it's mostly trial and error.:(
