Pio vsx1019, Onk sr607, Yam765 with Emotiva xpa-5?
Shock
Shock
Yeah I was looking at those reviews, however the thing that really stood out to me was that at 1.25 Vrms, you can still achieve 155 watt per channel into an 8 ohm load. 2 Vrms would be nearly 400 watts per channel, which is quite a lot for typical applications.
I would be quite interested in what the 765 and the 665 can do specifically. I personally have neither the funds or the need for an external amp that can output 400 watts per channel. Honestly I wouldn't even need 150 watts per channel.
Although they were both good reads.
Lordoftherings
Lordoftherings
Mix & Match, that's what it's all about.
Well the thing is, if you want to have preouts, might is well have them fully unclipped and with a high output (Vrms) for benefiting* by the addition of any external amp(s).
* I was just looking in my dictionary to see if the word "benefitting" took two "t" or just one. Happens that both ways are equally good! Oh well...
I did check for any reviews with the preouts tested on these Yamaha models (865, 765, 665, 565, 465, 863, 663, 563 & 463), and I could not find anything.
But my strong belief is that you need the right amp(s) to match with them, and not any amp, which make things tougher to mix & match.
And anyway, just like you, I don't have any need for this feature. My Onkyos are just fine with my speakers. And if I really want to use a receiver as a pre/pro, I will get the very best at the lowest price, which I already did with my Onkyo TX-SR805. But it just happens that I can also use it's internal amps. :)
And I know some other people that choose the Denon AVR-2808ci for that very purpose.
I don't think that there are too many people using a lesser receiver as a pre/pro only. Might is well get an Onkyo Pro PR-SC885P, when it was selling for only $529.
At the end, the mixing & matching thing is quite the important piece of the puzzle. Everything, your components (amps, preamps, HDMI...), your speakers, your wife, your room, your neighbours, your tolerance limits and even your pets.
On this, I'll discard myself.
