gmichael
You can be 10 degrees out of phase. Or 20, or 30, or 35.6781. But if you reverse the polarity, you will always be 180 degrees out of phase (but not really) There is a point that phase means a timing difference but a reversed polarity is not out of timing. But it does work out to be 99.999% the same thing.But then what is the difference between polarity and phase ?
--Regards,
Please step away from the hair.
