I got my pair of R7T's working with my 2 subs (Outlaw Ultra X-13) and Dirac Live and Dirac Bass, and it sounds great. It can go loud, but on rare momentary occasions I make it so loud that the R7Ts distort, so I back off so it does not distort. Probably is good that I reach that mechanical limit - to save my hearing (or destroy my hearing more slowly).
I have not experimented much with setting the Dirac sub crossover higher to see if the R7Ts could then go louder. Perlisten told me I should crossover about 30 to 40hz roughly.
The first time I did REW with the R7Ts I found out that one tower had a failed tweeter. I don't know if they were that way new, or if it happened later. Without REW I did not know. Perlisten sent me a replacement tweeter assembly, including good instructions and all is good now. No arguments. No cost. Their support was very good.
My living room with the R7T's is small. If you have a big living room, and like loud, I would get the S7T instead. Since my living room is small, and if I sit close to the speakers, and found that James' evaluation that the sound integrates quickly for good near listening is true. Perfect for my small living room! I set up various Dirac presets for near, mid, and far distance from the speakers. My couch is on carpet sliders. "Far" is not that far since my living room is small. I also have a Dirac setting for speech intelligibility.
If we gave a single loudness number, like a db number, to the R7T - then what would that number be for the S7T?
