walter duque
walter duque
I am not up to date on Blue-Ray Player specs. Since I don't see DTS on any BlueRay movies it must be that PCM 48Khz is the better sound than DD. My question is that I have a Rotel 1066 Processor and will that Processor reproduce this audio format or do I have to update my processor.
jliedeka
jliedeka
My guess is you would need a processor with HDMI to benefit from multichannel PCM. I think your coax (or TOSLink) is limited to Dolby Digital. I'm not aware of any discs that use basic DTS or DTS-ES. It's usually Dolby Digital or one of the higher resolution codecs.
Jim
racquetman
racquetman
If your blu-ray player has analog outputs, you can get any of the formats via that route. The player will need to do the decoding though.
E
edmcanuck
To paraphrase: I don't see any apples so it must be that grapes are better than plums.
I think you would do well to search the forum and find out about the new formats and how to listen to them through older equipment. You have some basics to cover before the advanced class.
walter duque
walter duque
Thanks for your help.
