PC + console setup using one DAC and headphones
Jan Piotrowicz
First of all I would like to say hello to everyone and thank You for a great deal of knowledge present on this forum.
My issue seems to be quite common but somehow I just cannot find the solution.
I need a way to connect my PC and Xbox sound to one receiver that will also output the sound. I would like to use an optical/USB cable from the PC (I dont do any gaming on the computer). That would be the first imput. Second one is the Xbox connected to my monitor using an HDMI cable. What I would like to achieve here is to output the sound coming from the console to the one receiver that will also accommodate the data coming from the PC. Then, I will be using headphones mainly (decent output is necessary) but also I would like to leave an option to connect active speakers later (so a line out).
The goal here is to avoid switching the headphones between the devices.
Should I go with a DAC? DAC + headphone amp? AV receiver? My budget is limited but if I have to I am prepared to save some money for the cause.
Thank You for You time and looking forward to replies.
(Also, if I were to use an AV reciever with a pass through function, would I be able to connect my PC monitor with HDMI to DVI cable coming from the receiver?)
Jan Piotrowicz
Actually, I just read that the pass through would not process the audio anyway so that is not an option.
