That makes sense. What doesn't make sense is how well this 10" 'ported' sub (100w, 250w peak) performed in my large room (about 5000 ft^3) with music and HT. Granted, the other 5 speakers are all full range Def Tech - all but center are bipolar), I prefer flat EQ, and my room is higher than it is wide. Everything I read says I should need a bigger sub or subs. Perhaps my demands are easy - volume rarely above -15 (I do value SQ over SPL but do appreciate a thump in the chest). I'm thinking any of the choices below will be an improvement:
Rythmik F12 or E15HP
SVS sb13u
JL e112
I know, apples an oranges, but I seem to want sealed and I have real space restrictions (even the E15 and sb13u are 2" too deep for my space), and only really need 60hz and lower. With my 'low' volume levels, the F12 is probably more than enough. What do you think? Are there other 'compact' sealed subs I should consider?
