maybe u should try to listen to some of the amps you want to buy with similier setup you have.
personally, i don't like how B&K sounds when connect to B&W speakers. however, many B&W dealers have this setup as starting point for customers. u will never know how a system sounds like by just looking at spec sheet.
a well-designed multi-channel amps shouldn't have crosstalk or interfence problems between channels. if you buy ONE multi-channel amp vs. many amps, you can usually go higher end products. sometimes, cables are the result of crosstalk and interfence. i am not saying you should buy super expensive cables but a properly shielded cable would helps a lot.
amps from different companies have different design, gain stage, and properties. a 200W amp from one company can sounds very different from a 200W from another. i would like to stick with one company if possible.
i am curious which class A/AB amp can do 120V and 230V without any mods. unless you go with switching power supply (class D amp) the transformer for 120V and 230V are basically different. um...
