Parasound 2125v2 thoughts?
Pandaman617
Pandaman617
Picking one up for $200 on Monday. I plan on using it to drive the Mirage HDT-F bookshelf speakers I use as surrounds as they’re a bit much for the Carver AV-705x to drive along with a pair of Paradigm Studio 60 v4’s. Any thoughts or concerns? I haven’t owned a Parasound product since the trio of HCA-1000’s I used years ago to drive an LCR setup of 3 Mirage OMD-28’s and I was content with their performance but they were replaced with GFA-555’s eventually. I figure for $200 worst case I can at least double my money if I’m not happy with it
K
Kleinst
Seems like a reasonable deal to me. Should last a long time (as long as it still works)
Danzilla31
The specs look good when I looked at the info on that model for 200 if it's working and in good shape I'd go for it
Replicant 7
Replicant 7
That's a sweet pickup! If you don't like it should be easy to flip. New it goes for over 1K, and it's a serviceable amp to boot if needed. Like Big Dan stated, specs look really good, 225 watts into 4 Ohm load, 150 into 8 Ohm load. If all is good when you test run it, a steel for two bills in my book. I'd wouldn't bet against it not punching above it's spec's.
Kvn_Walker
Kvn_Walker
200?!?
More like triple your money. 2125's are selling used for what the 2250's used to cost. They're great amps, with no shortage of power or features.
