Paradigm surround/rears thoughs and placement
dpnaugle
dpnaugle
Hi all
I am thinking about getting the ADP 590's to complete my 5.1 system. I have no room for floor or shelf rear speakers. I plan to mount the ADP's slightly forward of my seating position 6" below the ceiling. My TV and seating are opposite each other against the wall in a 15x15x8 room. There are constraint that demand the ADP be that high on the wall, approx 7' to center, however none for front to back positioning.
set up currently:
Denon 2807
Studio 60-front
cc590- center
svs sb-12 plus
Is this is a reasonable way to round out to 5.1
Thanks
DN
MDS
Dipoles like the ADP would be a good choice for surrounds especially given that the other speakers are also Paradigm. The height of them is not a problem but since you have no constraints on lateral placement, you should try to mount them either straight across from the listening position or slightly behind the listening position - that would match the Dolby recommended placement of 90-110 degrees from the listening position.
dpnaugle
dpnaugle
Got um.
They are nice little speakers. I'll let you all know how they sound after I mount them. One thing for sure is you have to be careful how you grab them to avoid poking a finger into them :)
DN
