Nobody is saying the Monitors aren't good, just that the Studios are better.
A higher sensitive speaker does not necessarily mean it will draw less current than a lower sensitivity speaker, because that will vary with the design of the speaker itself.
I know that impedance variations will influence the current draw, but are you going to tell me that a Studio 20, which is
7 dB less sensitive than the Monitor 11 (both having a nominal impedance of 8 ohms) will not require more current to acheive any given volume? I have to say, I'm somewhat sceptical. So, I would
still advise that this aspect of speaker selection should not be ignored.
As for "Nobody is saying the Monitors aren't good", well, that is the distinct impression that I'm getting. I take issue with that. Again, I'm not arguing that the Monitors are as good as the Studios and I'm not defending them just because I have them. I'm sure that there speakers of similar cost, that perform better. I just haven't heard 'em myself...
Smooth 2222 for the money you are willing to spend, you should consider an Axiom system, as previously suggested. I haven't heard them, but they've received fantastic reviews. If I'd been aware of Axiom when I was in the market, I think I would've been tempted to go that route myself. You will probably get better performance, at the same cost.
Other factors that should be considered:
A large room will demand more from your speakers and receiver. If your receiver can't deliver lots of current, your speakers need to be easy to drive, i.e. higher sensitivity, with impedance that doesn't dip too low. Of course, the smaller the room is, the less important these factors are. A smaller room may have space restrictions as well, although with the system you are considering, I'll assume that isn't the case!
Do you have a receiver now, or are you still considering that purchase?
If you have a well-damped room - carpets, lots of soft furniture, etc (which is what I have) - speakers that might be considered "bright", may suit such a room well. The inverse is true as well. If you have a lot of hard surfaces - ceramic tile/hardwood floors, bare walls, hard furniture - a speaker that tapers off the higher frequencies might be a better match.
I hope the "debate" between the Studios and Monitors isn't turning you off. I'm feeling somewhat abused however...Sniff...
Just kidding all you Studio aficionados! It's all good!
