Hi guys,
I have that Panasonic projector which is installed about 16" from the ceiling. It projects the image on a 92" diagonal (16:9) screen (tension fixed).
The screen is mounted 30" above the floor.
The projection distance is less than 5m.
To center the image on the screen, I had to use the lens shift to the max allowed (bottom-left).
For some reason, I cannot get a focused image. The text is too blurred.
I noticed that if I center the lens shift, the desired focus is achieved but the image is projected way too high and to the left so it's not a solution.
Please let me know if this is a problem with the projector or if I should change something else.
Thanks!
