Panasonic PT-AE900U Projector
L
lucas2k56
hi
i wna buy a projector to play dvds and games consoles and this one looked to be the best at that price range (if theres others at same value or cheaper please tell me) but im new and know nothing on porjectors and ive seen a cheap one selling on ebay so i kinda need info quick so b much appreicated.
just wanted to basically know what LCD projectors is all about (this is LCD one rite?) i mean wot differene is it to other non LCD projectors, is it the best tech avail? wot am i missing out on by gettin a LCD projector? also a lot of u talk about screens u get for it but i dont think i could afford one after buying this (inless they under 120 or so?) so is LCD projectors like this one same as others ive seen taht u can just project onto a white wall and alls good? i dont need a screen do i? also this vertical branding, is this something an average home user will care or notice too much? finally i take it u can hook it up to a tv or sky to watch normal tv on right, even though wont be HD?
thanks a lot
anyuse200
Your Questions hereby asked
lucas2k56 said:
hi
thanks a lot
You are probably better off getting the Optoma HD72,the sony hs51a.
The panny and the sanyo are reviwed(sanyo plz-4) on audioholics.
Lcd and Dlp projectors have their pros and cons, you can read up on it on audioholics. Dlp projectors have the cons of some people suffering from the "Rainbow effect" although some newer dlp projectors have a spinning wheel to minimize this.
The Rainbow effect means that for certain people they may see green,pink-and red colors offsetting motion to their eyes. You aren't missing out on getting an lcd projector in most cases especially at your budget, which you failed to mention. Carada.com sells highly rated projection screens on a budget, audioholics mentions those.
Getting a good screen is important, if you can't control ambient light some people end up with a greyish material on the screen, such as the stewart firehawk. Since the panny and all the other projectors I mentioned are HD projectors(720p native), you can watch Hdtv on the projector. Note you might need an Hd-capable box from your satellite or cable company. Regulat Tv channels would probably come through the same box to your projector- the box they give u, you hook it up to your projector. Whatever your box gives you, depends on the company, some normal tv is broadcasted in HD..
I stronly recommend you obtain a screen. I doubt why you would want to hook up a projector to your tv, I don't understand because if you are using the projector you probably won't be watching tv. If you are referring to watching source material(stuff you normally watch on your tv- or hooked up), then you probably need to hook up the game console and dvd player to your projector.
If you have an receiver- just simply hook up the receiver to your projector via component,hdmi,or dvi and attach all your stuff-game consoles, dvd players- to it. This is assuming your receiver supports it. Component video connections usually have a red blue and green sets where you plug in a cable. Of course almost every projector has composite,component, and s-video inputs as well as a dvi or Hdmi input-nowadays.
Your projector needs to be a certain distance from the screen , I belive at projectorcentral.com I think they have a calculator.
More questions helpful, that way I can help you out.
L
lucas2k56
thanks for ur reply really helpful. i looked at those others u listed but i found the panasonic one to be cheapest on ebay (less than £1k) and cant see much difference to pay much extra for the others. If there is anything bad about the panasonice one that u no of that i mite nt have picked up on from some reviews please tell me, but all reviews ive read say its excellent. the main concern i have is just i looked on that website and the screens for like 90 inches which i wud want are too expensive right now for me so at least for a while i wouldnt have one and would use the white wall i have in my room, but need to make sure it will be fine on a wall and not screen otherwise i will get one which is mor suitable for walls watching so that is wot im really after, thanks.
