Panasonic has released specifications for their highly anticipated upcoming BD-Live (Profile 2.0) Blu-ray player, the DMP-BD50. As a BD-Live player, the biggest difference between this player and the current BonusView (Profile 1.1) player is the Ethernet port. Also of note is that this player will support both internal decoding and bitstream output for Dolby TrueHD and DTS-HD (both HR and MA) audio formats and is a certified DivX product.
Here are some features:
Video Features
- PHL Reference Chroma Processor
- P4HD (Pixel Precision Progressive Processing for HD)
- Precise Pixel Generation
- 16-Level Motion Detection with Pixel-Based Motion Adaptive
- Diagonal Processing
- Detection of 3:2/2:2 Pull-Down Progressive Processing
- i/p Conversion for 1080p* Playback
- Up-Conversion to 1080p* Playback
- 1080/24p Playback (Blu-ray disc)
- HDMI™ V.1.3 with Deep Colour™ and "x.v.Colour" *1
- 148.5MHz/12bit Video D/A Converter
- Digital Noise Reduction (3D-NR/ Integrated NR)
- Picture Mode (Normal, Soft, Fine, Cinema, User)
- Picture Adjustment (Contrast, Brightness, Sharpness, Colour, Gamma Correction)
Audio Features
- Built-in Dolby® TrueHD, Dolby® Digital Plus and DTS™-HD*2 Decoder
- High Quality 192kHz/24bit Audio D/A Converter
- Pure Audio Components
- High-Speed 50Mbps Optical Output
- Audio Re-Master for All Formats (BD, DVD, CD, MP3 and DviX®*3)
- Advanced Surround (V.S.S.) Creates a Surround Effect for BD and DVD from Only Two Speakers (2 Modes)
- Dialogue Enhancer
- Dynamic Range Compression
Output
- HDMI AV Output
- Component Video Output
- S-Video Output
- Video Output
- 5.1ch Audio Output
- 2ch Audio Output
- Digital Audio Output (1 Optical, 1 Coaxial)
Convenience Features
- VIERA Link*4 for Panasonic Blu-ray Disc Product Line-up
- Movie (AVCHD) & JPEG View with SD Memory Card Slot
- JPEG Slide Show with Music
- Multi-Format Playback [BD-Video(BD-Live*5), DVD-Video, DVD-RAM, AVCHD (SD Memory Card/DVD), DVD-RW*6, DVD-R*6, DVD-R (Dual Layer)*6, +R*6, +R (Double Layer)*6, +RW*6, CD, CD-R/RW*7, MP3*8, JPEG, DivX®*3]
- Super Hi-Speed Scan: 5 Speeds up to x200
- Easy Setting Guide
- Graphical User Interface
- Audio/JPEG Navigation Menu
- Remote Control
Notes:
* HDMI connection required.
*1 x.v.Colour is a registered trademark.
*2 DTS-HD High Resolution Audio, DTS-HD Master Audio
*3 Official DivX® Certified product. Plays all versions of DivX® video (including DivX®6) with standard playback of DivX® media files. Certified to the DivX Home Theater Profile. GMC(Global Motion Compensation) is not supported. DivX®, DivX® Certified, and associated logos are trademarks of DivX®, Inc. and are used under license.
Maximum number of folders recognizable: 300 folders. (including the root folder)
Maximum number of files recognizable: 200 files
*4 This function is available for Panasonic products that support VIERA Link (HDAVI Control 3 or above).
*5 BD-ROM Profile 2
*6 Discs recorded and finalized on DVD video recorders/cameras.
*7 Playability may vary depending on the contents, discs and quality of the recording.
*8 For contents recorded on CD-R/RW for your personal use only.
