Mk Clampy
Mk Clampy
Hey, I'm looking for someone to proof read my homework, as I'm not sure if I'm missing anything to make these devices compatible. (Below is links to gear I'm hoping pairs) Thanks in advance.
Currently looking to pair an old receiver with my Samsung TV.
I'm looking at this receiver: (JVC RX-780V)
www.kijiji.ca
JVC model : rx-780v , AV receiver - $ 70. or fair offer | Stereo Systems & Home Theatre | Windsor Region | Kijiji
Stereo Receiver . - $ 70 . or fair offer , JVC rx-780v AV receiver . works as it should . call or text 519 520 1012 . - Neil . , . click on view listings . It will show you all my other adds . - i have many other stereo / audio components for sale in the other adds . .
www.kijiji.ca
www.kijiji.ca
https://i.ebayimg.com/00/s/ODAwWDYwMA==/z/5a0AAOSwTyhfdQg0/$_59.JPG
JVC RX-780V Audio Video Control Receiver Manual | HiFi Engine
www.hifiengine.com
www.hifiengine.com
& looking to pair it to my Samsung UN65RU7100F TV:
www.samsung.com
UN65RU7100F | UN65RU7100FXZC | CA
I have some lil 100 watt speakers and a fresh role of 16 gauge wire...
Tryna figure out how to hook it up via a convertor.
Not sure whether THIS: Amazon product
www.walmart.ca
Or THAT:
https://www.amazon.com/ViewHD-Extractor-Support-Converter-VHD-H2HARC/dp/B00LKF6CPG
I see one is audio and one is audio/video, but a little lost on whether I want to process audio separately.
Teetertotter?
Teetertotter?
If the JVC does not have any HDMI ARC out to TV HDMI ARC, this receiver would not be for me.
If you are using cable or satellite, the receiver would have to have HDMI Out to HDMI monitor IN to the JVC.
Find a AV with HDMI inputs and outputs. looooooong story short.
Mk Clampy
Mk Clampy
Thanks for the reply. Let's suppose I wanted to pair old gear with new gear.
What are the draw backs, because at the end of the day, can the conversion hold close to the level of audio qualify expected from the original source along the intended transfer cable/ins outs?
Words like 48 khs, or 24bit sample rate come to mind as a musician. If the loss of fidelity is minor enough, it's still a big improvement on tv speakers.
Will applications like netflix be coded in a way where this old gear will fail to make sense of the information?
I don't know much about theater audio and how it's evolved, and what devices support what format, or if everything just defaults to the old dolby digital, when in doubt.
I just would like to know what the "problems" are with trying to pair hardware like this, so that I can understand if it's literally pointless, or not really worth it, or worth it with drawbacks but still an improvement, or if it's A OKAY and there won't likely be any complications rendering the information for my ears.
I don't know if I stumbled upon a forum geared towards people who only buy hi-end, and if no one is into mixed pairing, or thrifty buys.
Can someone point me in the right direction, if you've seen forums or a different sections that are more geared to what I'm looking for.
Plenty of cheap bastids around here :) Not really a high end place in general altho some members do have some very nice stuff! We're generally practical around here.
I'd agree that the old gear for a receiver is just not going to meld well with modern streaming needs generally. Adding in conversion units mostly just brings a chance to degrade the signal. Netflix is a good example, to get Dolby Digital Plus (DD+) (different from Dolby Digital), which is what Netflix and some others use for encoding audio for their video streams, this is best for an hdmi connection. Let alone the video, where hdmi has largely replaced previous video connections like component video.
Not sure why you're thinking of 24/48khz encoding particularly, but that's just one of a few audio coding/codecs to consider. HDMI can carry all of them, optical and digital coax not quite as much (only up to Dolby Digital 5.1 generally).
A modern avr can do it all pretty much.....the JVC is almost 22 years old....ancient in AV terms.
If you go to the AV Research tab there are a lot of good basic knowledge articles/videos to check out....welcome aboard.
panteragstk
panteragstk
There are way too many cheap/refurbished options for me to ever consider a receiver like that JVC. You can always use it for something else, but without HDMI, it'll just annoy you.
