The differences in the power tables is pretty compelling between the UPA=500 and the Outlaw!
IME, when they do not perform the standard tests, it reflects that an amp does not perform so well at that task.
For the UPA-500, note that they did not even do the standard CFP-BW 2-channel test of the UPA-500, they "dummied it down" to
one channel, and even then, the
THD+N is at 1.0%! 1% THD is a low bar for modern electronics.
In comparison, The Outlaw was tested for
2 channels at
0.1% THD+N, and is even tested for 5 channels driven!
I am no expert, but someone like
@PENG will be along before long to let us know if I am spouting BS!
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My understanding is the transformer determines how much
steady power is available to all channels and is reflected in the CFP-BW measurement, because the load is continuous and steady - a capacitor gets emptied and doesn't have the opportunity to recharge once the load is taxing the transformer.
The 1kHz powersweep and the dynamic power measurements are both short-term pulse type measurements. As I understand it a capacitor allows an amp to reach levels of power above what the transformer allows. They are essentially a battery that charges up when there is extra power available from the transformer (not being used at that moment). When a spike in load comes (from a short loud sound), the capacitor discharges to add the extra oomph/power required.
UPA-500 has a lot of reserve from the batteries, but Outlaw offers the steady power to where the capacitors are not needed so often.
Either can run out of steam and I don't know how you can
guarantee it wouldn't without getting different speakers or a very serious amp. However, based on the continuous and short term power capabilities, the Outlaw offers considerably more power across the board than the Emotiva.
If you still had teh Denon or any other amp, I would suggest that you could get the OUtlaw and run 2, 3, and 5 channels from it to see if and when it runs out of steam. I think it is safe that it would do 3 channels and you could use the other amp to do the 2 surrounds without issue.
Simply put, I believe the Outlaw represents (by a nice margin) the best value in a budget amp (aside from pro audio amps).
However, the only way to assure it will do the job beforehand is to buy an amp that offers over-kill (as in $$$$)!
Outlaw does have a 30 day return policy, but you pay shipping.
