Buckle-meister said:
They're a fine looking pair of speakers, but how do they sound...
Refer to "brief summary of initial subjective impressions" above. Basically, they're <b>at least</b> the equal of any other speaker I have ever heard, regardless of price. Not that I've heard most of the megabuck speakers out there but I've heard a few very highly regarded ones. Name the criterion: bass, clean midrange and highs, general transparency/neutrality, soundstaging...they excel in all. My room is now, by far, the major constraint on my system.
...and what's the thinking behind not having an enclosed cabinet like 99.9% of all other speakers?
Saves money on MDF.
Also, that's how you make a dipole speaker. (EDIT: Think of it as a Magnepan, only with cones instead of panels or ribbons.) One reason for going dipole is subjectively more natural sounding bass. Linkwitz goes into exhaustive detail on how that works and why he prefers dipoles on his site. Pulling it off requires very close attention to the baffle and sidewall dimensions, plus tailored EQ to compensate for the bass rolloff that would otherwise occur with an open baffle. In turn, that requires bass drivers with a lot of excursion and low distortion.
And the push-pull woofer mounting is to cancel distortion due to the naturally assymetric output of a cone driver due to the basket and magnet structure. (The guy thinks of everything!) They're wired out of phase so they will still move "in phase": in other words, toward or away from the listener together.
I've since added a grillecloth to the bottom section so no one else will be alarmed by the "mistake".
There's a source in Europe for precut kits and complete speakers. Now that you've got your room sorted you need another project, right?
