Optoma HD70 Projector Review - $999 for 720p DLP!
N
nucoolmint
phidelt said:
Great review, what led me here was a problem with my HD70 that I think may be easily corrected. I have 25FT runs of both SCART/Component and straight component cables - each of which I have hooked up to my 5-7 year old Sony DVD player (dont have model # handy). My issue is that during indiscriminate times or scenes, the HD70 will "drop" the image completely with its blue splash screen, 2-5 seconds later, the image comes back. I have tried it with a SCART/Component cable as well as the straight component port and the same thing happens, even at the exact same moment in the scene on the DVD. I ran DVD over SVIDEO and no signal problems at all. My HDMI source (cable TV) has never dropped either.
Is this a cable problem? A signal degradation problem? a projector problem? If I had a spare DVD player that was easily removeable, my plan was to move it closer to the projector and test a different DVD player with a shorter cable, but I haven't been able to do that yet. It seems to happen with action scenes/sequences, and less on dramatic slightly moving images.
Any ideas would be greatly appreciated.
I have the same problem it drops in and out. I have the Sony DVD S5550D and the HD70. It works fine on S-Video. My cable run is aprox 33 feet. The image on component when present looks great. Is this a cable problem or HD70 not being able to hold on to the sync or maybe just the DVD player.
Cheers
billnchristy
What kind of time frame does it take for this to happen?
N
nucoolmint
This was a problem with the DVD player. I now have the oppo 970HD and the component cables work fine.
patriciogac
Clint:
Great review!
I tryed using Avia for calibration, but i did not like the results. can you publish the calibration numbers for the optoma d70 that the datacolor showed? Thank you!
