I purchased a refurb HD200X and it looks like it has a problem right out of the box. The projector works fine except for one issue - the power led continually flashes green whether in power up mode, while running, or when turned off. If you unplug it from the wall and then plug it back in, only then will the led turn solid amber. Other than this issue, the projector is great. Any ideas?
