<font color='#000000'>Hello all,
Can anyone enlighten me on the use of either of the above mentioned cables for DVD audio? I'm hearing the optics are superb one place, and another place says they produce bright sounds, which could make my Klipsch KG5.5 unbearable (as they are pretty bright by themselves). Also heard the Optic cables are succeptible to sonic jitter and can mess with the sound if they are off just a bit. This same guy recommended using Coax connecter's for sound, as they produce a flatter range fidelity. I just purchased the Yamaha 2400 tuner/amp if this helps.
Any real life experience on this issue?
Thanks!
1db</font>
