Hi,
I want to build an audio system to support both home theater and music listening. Most of what I read online recommends to choose (and spend most $$ on) speakers first so that is what I'm attempting to do. Then I will choose a receiver. I would like to stay under $1000 for speakers if possible. My room is about 15'x15' but almost every wall has windows or doorways or fireplace or openings to other rooms... you get the idea. I have a diagram but don't know how to post it.
I am also interested in opinions on using my current speakers as mains. I'm the original owner of a set of B&O RL60.2 - here are the specs and a link to photo and description:
Beovox RL 60.2 Passive Loudspeakers Product Specifications
Type: 6513 (1988 - May 1992)
Dimensions W x H x D: 54 x 40 x 18cm
Weight 8.3 kg
Long-term max. input power 75 W
Maximum noise power 45 W
Speaker impedance 8 ohms
Frequency range 42 - 20,000 Hz
Power at 96 dB SPL 2 watts
Sensitivity 1 W 93 dB
Distortion < 0.5 %
Cabinet principle: Bass Reflex
Woofer: 2 x 13cm
Tweeter: 2.5cm
Crossover frequency 350 Hz
Net volume 19 litre
Connections: spring terminals
DIN socket
www beoworld.org/prod_details.asp?pid=659
My interest in using these is 50% sentimental and 50% frugal. I just don't know if their design is compatible with today's HT systems and the other speakers I would need to complete a 5.1 system.
I've read good things about SVS subs. With my budget, the PC12 or PB12 NSD would be a stretch (about $600 with freight), and would not leave much room for the remaining speakers.
I'd like to find surrounds that are relatively small but effective, and easy on the eyes if mounted up high.
I'm clueless what to use for a center.
One twist - my wife "might" be giving me a pair of Polk RTI A5's for Christmas. I don't know much about them other than they are recommended at Fry's - supposedly there was a sale for 50% (sounds too good to be true) off that she found out about - not sure if she executed the transaction or not though (I'll know more in a few days
. I could always return them and use the funds elsewhere if my RL60.2's are worthy as mains or if there are better choices for mains in my budget range. Again - opinions are appreciated.
Thanks in advance for helping with my research. I live just north of Dallas area so hopefully there are stores in the area where I can listen to speakers that are suggested.
Sam
