Only $7000. per channel
Adam
Adam
I like how the reviewer makes an especially big deal about the chassis being made out of a single piece of aluminum, and how it's so special that each feature is "created by cutting away precious chunks of aluminum."
I guess aluminum isn't especially previous, but the chunks must be. :)
There must be a lid on the bottom face or else they couldn't get the electronics inside the box. Now, if there is not lid (and also no open cavity on the bottom), then I'll be impressed.
3db
3db
Thats a balanced design with a floating ground perhaps? ;) :p
cpp
cpp
wow that's how my wheels on my car are made, right out of forged billets of 6061 aluminum.
For that kind of cash, it better keep the beer at the perfect temp, make good coffee and wash the dishes too :rolleyes: I can't see a solid machined block case adding any real world benefit to the amp.
Not exactly :) Forged and machined rims are different things. They do not forge a block of aluminum and then machine it, that would serve little purpose. Machined rims are machined from a chunk while forged rims are actually "compressed" into their shape. They do machine some rims after forging to lighten them further, but we are talking about small amounts of material removed from specific places, not machining the final shape. Forged rims are generally MUCH lighter and stronger than a comparable machined rim, but they are also quite a bit more expensive because forging isn't cheap. On my old car, my forged 16" rims were lighter than the 15" machined aluminum ones they replaced. The price difference between the two was almost 3X for the forged.
cpp
cpp
Quote:
Not exactly Forged and machined rims are different things. They do not forge a block of aluminum and then machine it, that would serve little purpose. Machined rims are machined from a chunk while forged rims are actually "compressed" into their shape. They do machine some rims after forging to lighten them further, but we are talking about small amounts of material removed from specific places, not machining the final shape. Forged rims are generally MUCH lighter and stronger than a comparable machined rim, but they are also quite a bit more expensive because forging isn't cheap. On my old car, my forged 16" rims were lighter than the 15" machined aluminum ones they replaced. The price difference between the two was almost 3X for the forged.
Thanks for the info...
GranteedEV
GranteedEV
you guys are so negative :eek:
the reviewer said it's the best amplifier he's EVER heard :D
:rolleyes:
Irvrobinson
Irvrobinson
There are multiple ways of making forged rims. One way, used by HRE and Fikse, for example, for the centers on three-piece wheels, is to take a forged solid disc and literally machine away the entire pattern including openings. Gibson does the same thing but uses billets. Here's a link to a video showing the process for HRE:
How HRE Forged Wheels Are Made - The Octane Report - YouTube
The VX-R delivers 200Wpc into 8 ohms or 400Wpc into 4 ohms, 5 yr warranty, $15,000 stereo amp.
What a joke!:D
I don't think people will buy that.
They would buy the Bryston 14B-SST2 600 WPC stereo amp for only $10K with the 20 yr warranty. I bet I can't get it for $5K.:D
Bryston - 14B-SST2 - 600 Watt - Stereo Amplifier-Audio Advisor
I'll probably go the Bryston 20 yr route if I ever need new amps. :D
Yeah, that's a different process than what I was talking about, and I believe it is Foose that came up with that. Machining forged blanks to make centers isn't the same thing as forging a whole rim; it is kind of a hybrid. What I was referring to were one piece forged rims. I saw the process on some Foose special on Speed. I think he owns HRE or is somehow connected to them.
96cobra10101
96cobra10101
He doesn't own these guys, and they do the same thing.
BMF
Hocky
Foose has nothing to do with HRE.
BMF
There are plenty of places that make three piece rims like that, and those types of rims have been around for many years. Wasn't saying that Foose or HRE were the only ones that did.
I don't recall what the show said, but Foose was at the manufacturing facility of another company, which I thought was odd since he has his own. I was pretty sure it wasn't his company though, and I could swear it was HRE, but it might have been another one.
Hocky
Foose has a wheel "brand," but they're built at some no name Chinese plant. Could've been there.
