Onkyo TX-SR602 vs. Yamaha RX-V650, please help me with choice!
Berlin
In case your interested
Push pull...great design.
If you really want to see the champions of the push pull Subwoofer look at M&K's.
Check out the MX-5000 MK II THX ULTRA:
http://www.mksound.com/subwoofer.php
Also take note of just some of the companies that use them:
Dolby Labs
Disney
Lucasfilm
Sony Pictures
Goodnight LA Studio
Pioneer Video Manufacturing
DTS Corporation
O' Henry Studio
Enterprise Recording FCC Advanced TV Committee
HD Vision Studios
NARAS (Grammy Awards)
Motorola DSP Audio Labs
Walter Afanasieff
http://www.mksound.com/mx5000.htm
CosmicOne
nadrealista
the the Yammy RXV550 & 650 has alot more differences than 5w power
the 650 have over the 550
1-Pure direct mode (which is the best for music)
2-heavier Power supply than the 550
3-YAPO
4-Pre outs
i don't remember if there's more but in ur case u may find the Pure Direct on the 650 in music better than the Onkyo (maybe,maybe not)
N
nadrealista
CosmicOne said:
nadrealista
3-YAPO
4-Pre outs
Does anyone know if I can for example listen radio in my main room(using all chanel stereo mode) and cd in other room from zone 2 powered speaker with yamaha 650?
Berlin
Upon further research
Upon further research I can tell you this. Yamaha has a better processor for Dolby Digital channel separation then most other manufacturers. In addition to the fact that the Yamaha comes with YPAO, their proprietary parametric room equalizer; although I have found these type of auto EQ devices to be very poor at setting up a system "accurately"; for that you need the human ear. I say this to you, even though I personally own two Onkyo Receivers. Onkyo makes outstanding receivers. In fact my old one never died. I moved it to another room where it still works beautifully (unfortunately it is not capable of doing Dobly Digital or I would still be using it in my Home Theater). I have been doing this a long time now; longer then most. I have had a home theater for well over ten years now. Now I have a 6.1 system...soon it will be time for a THX Ultra2 7.1 channel receiver. It never ends... :D
N
nadrealista
Berlin said:
Upon further research I can tell you this. Yamaha has a better processor for Dolby Digital channel separation then most other manufacturers. In addition to the fact that the Yamaha comes with YPAO, their proprietary parametric room equalizer make it the "better" choice for HT imho. I say this to you, even though I personally own two Onkyo Receivers. Onkyo makes outstanding receivers. In fact my old one never died. I moved it to another room where it still works beautifully (unfortunately it is not capable of doing Dobly Digital or I would still be using it in my Home Theater). I have been doing this a long time now; longer then most. I have had a home theater for well over ten years now. Now I have a 6.1 system...soon it will be time for a THX Ultra2 7.1 channel receiver. It never ends... :D
Well I did lot of testing and Onkyo is superior as far is music concerned...Yamaha is slightly better with movies..but just slightly...music just doesn't sound as good with Yamaha..Onkyo has same thing like yamaha's YPAO but you can also adjust each speaker manualy (each has its own GEQ) which comes in pretty handy...
Feature wise they are evenly matched....
Another interesting thing that cought my eye is power rating of the units...
Yamaha uses 430 Watts while Onkyo uses whoping 800Watts..
To put real power out you have to use some...this probably has to do with how they go about amplification and their amp types...
So for me it will be Onkyo...
Thanks all of you for your advice!!
Dejan
Berlin
Onkyo (Japanese for Audio)
LOL...I said in my first reply to you that you couldnt go wrong with the Onkyo. :D
S.R. Johnson
S.R. Johnson
It is true that the yamaha is great for movies and the Onkyo is great for music
but if you want a receiver that is 50/50 for both, then i suggest getting a marantz receiver. Like for example i am thinking of getting of the Marantz Sr-7400 for $599 at www.ac4l.com or get the Pioneer VSX-1014TX-K for less at my friend's job at best buy. ;)
