I have old PC with a VGA video output, that I am trying to connect to my Onkyo 608 receiver via its PC in VGA input.
However, when I make the connection, the screen resolution from the computer to the receiver is 640x480. This makes the screen so small and then all the icons and desktop so BIG on the screen.
When I used to connect the same PC to my Toshiba TV via the same VGA wire, I was able to adjust the resolution to something like 1280x1024 making all the icons much smaller and fit nicer, similar to what you would see if the PC was connected to a monitor. The Toshiba was able to detect the PC as SVGA.
Through the Onkyo, I can't set the resolution on the computer to anything but 640x480.
Does anyone know what to do to fix this?
Thanks.
