Onkyo receiver - no sound
K
kmcorolla15
I have an Onkyo TX-NR5100 that has been working just fine up until recently. I've had to turn it off and back on to get the sound to work. This has happened at least 3 or 4 times over the last couple of weeks. It works fine after that. Is this a sign of a failing HDMI board? I've heard of this happening with other Onkyo receivers.
Thanks in advance!
Thanks in advance!
We have not had reports of newer Onkyo receivers having HDMI board problems. However, your issue sounds as if your receiver is heading for failure due to some fault or other.
K
kmcorolla15
I've had it for about 3 and a half years, and we were running it a lot before it got moved to our home office.
I'd try a soft reset to see if that clears things up (i.e. unplug the avr from power for a bit) or perhaps a full reset.
Teetertotter?
Teetertotter?
You might, also, want to unplug and replug the HDMI cable. Next, try a different HDMI cable.
Let us know how you made our or not.
K
kmcorolla15
I reset the connection on the back of the receiver and it started working after about 15 seconds. Getting behind the TV is going to be a bit difficult but I can try it if necessary.
BFreidah
Swap out another hdmi cable to eliminate that possibility. It happens.
I agree. It seems like imminent failure.
Good thing he got 3.5YR of use and it wasn’t very expensive.
