Onkyo receiever late night function
  • Thread starter guitarplyrstevo
  • Start date
G
guitarplyrstevo
Whenever I try to activate the late night function, it says not available. Same goes for the cinema filter. What am I doing wrong?
BTW my receiver is the Onkyo TX-SR574
MDS
It's only available for Dolby Digital - either DD 2.0 or DD 5.1.
G
guitarplyrstevo
So does that mean it only works with DVD's? My receiver is connected through a digital coaxial cable from my computers motherboard and whenever I put in a DVD it still says not available.
MDS
It will work with any source that is outputting Dolby Digital. My DVD player and my cable box both work. You have to make sure your source devices are set to output DD.
DVD player
Set it to output 'bitstream'. Sometimes there is a single 'digital out' setting and sometimes there are separate settings for DD and DTS.
Cable box
Mine (Scientific Atlanta) has a menu option called 'digital audio out' and it can be set to DD or 'Other' (which reallly means PCM). Most cable boxes are similar - set it to DD.
Computer sound card
This is where it gets tricky as it depends on the capabilities of your card. You have to find the setting that enables digital output for one thing but I assume you've done that if you are connected via a coaxial cable. The card's control panel may also have a setting for 'DD pass-thru' and you want that set on or it will decode it and downmix to 2 channel PCM.
You may also have to set similar settings in the media player you are using to play DVDs. If your receiver shows PCM then you do not have the DD output settings on or your card is not capable of outputting the bitstream.
Alex2507
Alex2507
My Motorola cable box audio is set to Dolby Digital (AC3). I'm just adding the (AC3) to what MDS said in case it might help you identify the setting required to get a digital signal to your receiver.
