Now, the Onkyo receivers that run hotter than usual are the 705 and up.
The 605 was not as hot as the 705 or 805 etc.
The 606 and 607 runs cooler than the 605.
Now, the part that runs hot on these Onkyo receivers are the video processors. That is the place where the most heat is generated, in the top right rear part of the receiver. That's why few people are using a small fan in that spot of the receiver mostly with the 805 and up (the 806 is not as hot).
And some people feel better putting a small fan too with the 705.
Now, there are tips to eliminate that issue, leave at least 4 inches of room in top of the receiver and leave the rear open, and front too. Don't cram your receiver in the drawer or the dryer.
Or a confine space, closed on all faces. A receiver or amp needs some room to breathe. My rack, I remove the doors and I remove the cardboard from the rear. If I will remove the sides, it will not hold anymore.
Also, you can make your receiver run cooler by disabling the Control (CEC HDMI).
And by disabling also the Power Control (CEC for RIHD via HDMI).
And by disabling the TV Control (RIHD via HDMI).
These are all useless features that consume a lot of energy to waste.
You'll save some money too on your energy bill.
Other useless features best to disable too: Lip Sync. xvYCC and Immediate Display.
Let me tell you this too, I personally own the 805 and the 876, and I crank up the volume close to Reference level sometimes, till my ears cannot take it anymore, and I don't use a god dam fan on either of them. I will burn out my ears first way before my Onkyos explode in a Big Ball of Fire like a Volcano from Hell.
If you guys are so worry about what is not there, why don't you buy a receiver and just keep it turn Off.
Or go to an audio store and ask the dealer to turn all the receivers to their maximum volume (well not all at the same time
), and for a few minutes, then touch the top of each receiver and buy the one that feel the coldest.
I bet it will be the one with the coldest sound too.
Ouf, I'm getting tired at this... Need a break.
Come on guys, just cool off.
Bob
