Hi all,
I'm new here and am not an audiophile, but I don't know where else I could post this kind of question. Sorry in advance for the long post, but I have tried to do my homework and try as many things as possible so I can give you a clear picture of the problem and what I've tried.
I have a pretty weird problem with my receiver and speakers. First the models:
Onkyo HT-R340
Speakers came with it
Front Left and Right: SKF-340F 120W 6ohms
Center: SKC-340C 120W 6ohms
Back Left + Right: SKS-340S 120W 6ohms
The problem is that whenever the three front speakers (left, right and center) are connected, there is a feedback humming sound and I can hear indistinct voices through it, as if I were hearing the radio. If I disconnect any one of the front speakers, the hum disappears. It can be any of the three.
Things I have tried that didn't change anything:
- I tried replacing one of the speaker cables (the center one) with another one. Didn't work. All cables are in good condition with no visible breaks or anything.
- I have disconnected everything, it happens with <b>only</b> the three front speakers and power connected. No sources connected to the receiver at all.
- I have also tested with all my other equipment (cable box, TV, consoles, DVD/BD player) unplugged from the power outlets, and all other wall plugs (network, cable for internet and digital cable TV, telephone) disconnected.
- I tried putting more distance between the three front speakers, but even at the width of my room (and the center speaker evenly between the left and right) it didn't change anything.
But, I did try one thing that worked, and that puzzled me. At the receiver, I tried plugging the Front Left speaker's cable into the Rear Right output, and vice versa. The hum disappeared. But, if instead of switching the connections at the receiver, I switched the speakers (i.e. the Rear Right speaker plugged into the Front Left output using the Front Left cable) then the hum was still there.
Also, the hum doesn't get louder when I increase the volume. It just stays the same (but is too loud to be ignored over an audio source playing at normal volume).
I'm probably going to go buy a reel of speaker cable tomorrow and replace all the speaker cables, but I'm dubious as to whether that'll change anything.
Could anyone suggest what the problem might be?
Thanks in advance,
Skylark
