Onkyo DVD receiver won't stay on
MountainHigh
I have an Onkyo DR-S 2.2 that won't stay on. The unit powers up & the tray opens. Then it shuts off immediately after the tray shuts. I don't know any history about this receiver. If anyone has any suggestion as to what might cause it to do this. Any help will be greatly appreciated!!
Turn the speakers off and see if it still does it. If not, you may have a shorted speaker wire or a problem with a speaker. If it still does it, find a way to save your configuration and look for a way to do a hard reset.
How much space is around the receiver? Onkyo receivers run hotter than most and need clearance or forced air to keep them cool. Running it hard without good ventilation will kill it.
