I sort of hate to ask this, it's
NOT a 'which is the best' thread.
Between these models;
Onkyo TX-SR604,
Pioneer VSX-1016TXV,
Yamaha RX-V659,
Denon AVR-1507
For this application;
HDTV w/ optical out and two HDMI inputs,
4.0 speaker setup (yes, it's only a 4.0),
CD player w/ optical out (separate source, separate zone option desired),
DVD player w/ HDMI & optical out,
HD DVR w/ HDMI & optical out,
Computer w/ DVI out,
FTA satellite receiver w/ S/PDIF out
1. The HDMI issue (since only the first two have HDMI), can any receiver pass the audio through using just HDMI, or do you have to use a optical connection also? I know I can get an external HDMI switch since the TV only has two HDMI inputs, but other than conveinance, is there some other reason running to the audio receiver first is better that using an external switch?
2. Is there really any audible difference at this level of quality using speakers well under $1k a pair? Or to put it another way, what price range (speakers) would you have to go to to hear a difference?
3. Is Yamaha still 'better' (overall quality) as they were in the 80s' considering their higher price?
4. If I went with the cheaper Denon, (between $120 & $160 less than the others) other than the lack of HDMI and multi source capability, what other shortcomings would it have?
Thanks in advance.
