Onix X-sls & Onkyo Tx-sr604
I
iamnotaparkbenc
Hi guys,
I decided to skip on the ONIX x-ls today because I just realized I require a stand and the total costs would be more expensive than a pair of X-sls.
My question is Does ONKYO TX-SR605 will be enough to power the speakers? in the long run, I will include X-ls as surround and X-cs as center.
Thank you for your help guys.
rnatalli
You should be fine. That's a good setup to start with and adding the center and surrounds later is a good call if your budget is tight now.
Gimpy Ric
Gimpy Ric
Moderator
The Onkyo 605 will drive most any speaker with a sensitivity rating of 86 db 1 watt @ 1 meter or greater. Every 3 db represents a double in power, or a double in loudness. So try and make sure your speakers aren't power hogs, i.e. sensitivity less than 86 db 1w/1m.
I
iamnotaparkbenc
Whew, I am glad to hear that...
Thank you guys
Should be fine. You can get some good stands for $65/pr at Parts Express too though.
