Most of the suspension is missing. Those drivers had foam suspension that dried. New foam suspension would need to be installed, and it would require to have the exact compliance as the original. That's about impossible to find nowadays. IMO best thing to do is to return them for refund if you can. The seller is a swindler.
Suspension? The surrounds? Those only last 20-25 years. Of course I bought them knowing that. I am referring to the cone being bent to the right. He is not a swindler. Bad packer, yes probably. Fed ex beat the h. e. double toothpicks out of the box. But you should anticipate that and pack them accordingly.
But this damage has nothing to do with the surrounds being deteriorated.
Hoping someone pipes in here to tell me what they think is going on here. You cannot simply move the cone leftwardly. It moves in and out like it is supposed to of course, but it is imoveable (is that a word?) to the left to make it straight or centered. I am not forcing it. Because something I do not understand is going on here.
