? on Zone 2 w/ 12v trigger
Pensacola Hi-Fi
I have a Yamaha receiver in my living room and want to use the zone 2 capabilities for speakers on my porch.
My current set up in the living room has amps with the 12v trigger going to Amps that power the home theater. Is there a way that I can set it up so that the trigger does not turn on the amps when I just want to use zone 2? The receiver is the RX-V565.
Can I install a switch on the trigger cable? If so, where would I find such a thing? Did not find one at Parts Plus, but that does not mean there is not one.... or do I have to make it. Not scared to do that.
Thanks in advance for the help.
Is the 12V trigger assignable? I don't think it is, but you need to read the manual to make sure. You won't find a ready made switch for this but it takes four parts- a small box to house it, the switch and two 3.5mm jacks. It's not high current or load-dependent and as long as +/- are consistent, it won't hurt anything. The only thing that's close to pre-made and would work is an A/B switch for guitar effects but you would need 2 3.5mm-1/4" plug adapters and it would come to about $30, which is excessive, IMO. Radio Shack has all of the parts you need.
WaynePflughaupt
WaynePflughaupt
What will a switch on the trigger cable do for you that the power switch on the amp won’t?
Regards,
Wayne A. Pflughaupt
Regards,
Wayne A. Pflughaupt
Depends on how accessible the power switch is.
Pensacola Hi-Fi
Thanks for the info. I have a salamander rack with the perforated doors. I am going to try to make the switch and install it on the bottom side of top. I have 3 amps... and turning them off would not be a problem, just looking to do it fast with one easy trigger.
