Old school Linn Helix LS 150 speakers for home theater system?
bweier
Hello everyone and thank you in advance for taking the time to help me with my question(s).
Ok, so I bought a MartinLogan MLT-1 5.1CH Home Theater Speaker System and then I got to thinking. Why not use my old Linn Helix LS 150 speakers as the (2) fronts and turn the 5.1 into a 7.1 system? Here are my questions:
  • Are these old Linn Helix LS 150 speakers superior quality to the MartinLogan speakers even though they are almost 30 years old? I should mention I replaced the old Linn speaker wires with Linn K400 speaker wires last year.
  • If the Linns are better, will they work from a compatibility standpoint with the MartinLogans to form a 7.1 system?
Finally, in regards to my receiver. I had originally chosen the YAMAHA RX-V473BL 5.1-Channel Network AV Receiver before I thought of the Linns. If a 7.1 system makes sense using the Linns, will my new receiver choice of the Pioneer VSX-1022-K 7.1-Channel 3D Ready A/V Receiver have any issues driving both the Linns and the MartinLogans at the same time?
Once again, thanks in advance for helping take the time to help me make a good informed decision. All (3) bolded items are from NewEgg and since I am a new member I can't post the url links...:(
Thanks!!
bweier
So after educating myself a bit, here is what I am leaning towards:
YAMAHA RX-V673BL 7.2 can be had for $339 on newegg (after a $210 gift card is mailed to me). I will use that gift card on the MartinLogan MLT-2 5.1 instead of the MLT-1 5.1 speakers which are $50 more. Both will be combined $639 which is a great price imho.
This way, I can future proof my purchase a bit and go 7.1 regardless of my old speakers if I decide to in the future. Still would love some feedback!
Thanks
zieglj01
zieglj01
The Yamaha 673 is a better choice.
However using the old Linn speakers, with the small Martin center speaker,
will be a poor match for home theater. I would aim for larger speakers than
the Martin Logan system, for the over-all Home Theater set-up.
Depending on budget, you can build sections at a time.
bweier
So in your opinion the Linns could work as fronts but consider building a more robust speaker system around them?
zieglj01
zieglj01
I would prefer to use the Linn's as stereo music speakers, and have
a seperate 5.1 movie set-up.
